Larger oil cooler
Larger oil cooler
I'm looking for a larger oil cooler with pipe for my z1100r. Anybody got anything before I look on eBay.
Re: Larger oil cooler
What size cooler you after
Not sure really. Something that is going to do the right job and not to ugly.
I have a 13 row cooler on my bikes. It's quite an expensive job all in though as you'll need to change the take offs, lines (with appropriate fittings) and cooler plus buy a mounting bracket. Earl's is the name most gravitate to but they are mega expensive. I use Mocal or Setrab. Slightly cheaper but good quality. Talk to Dave at Saisei as i think PMC do a complete kit.
If you go down the 13 row route i do have a KipKawa Z1000S mounting bracket I'd part with. Bolts to frame where horn mounts go and at the bottom uses original cooler mounting points. Looks just like Eddie's!!
