Looking for a standard liner to replace one liner and 1170 piston that has damage to it.
Will consider anything with at least one standard size liner as it will be bored to 1170 anyway.
Can anyone help?
Also if anyone has an 1170 wiseco new high comp piston kicking about give us a shout.
Cheers.
GPZ11 Z1000J etc. liner/std barrels needed
Re: GPZ11 Z1000J etc. liner/std barrels needed
Doesn't it have to be an 1100 barrel to be bored to 75mm, I don't think you can go that big with 1000J barrels.
Re: GPZ11 Z1100 etc. liner/std barrels needed
Julian yes actually your right its an 1100 sleeve we need its for Bobs Gpz.
I assumed it was for Bob, I think MTC do 76mm pistons for 18mm gudgeon pins, I don't know if 76mm will be solve Bob's problem, if it's a 17mm gudgeon pin engine then MTC and Wiseco may do 76mm pistons, but the Wiseco ones might not fit J type engines.
its a unitrac so 18mm gudgeon pins.
But its the liners he needs desperately as he can source a new wiseco from the states.
- 8 Valve Mark
hi kwacker,i could probably part with some 1089 barrels i have in storage (from z1100a shafty) if it would help you out.i believe theyre standard bore..im in glasgow but will post at cost but probably not till next week..let me know if they sound appealing and we'll sort the fine details out. ride safe mark. add phone number if poss
Mark, that would be cool, just let us know when you can.
- 8 Valve Mark
ok mate,I'll be in touch when i check them out.
Users browsing this forum: Bing [Bot] and 113 guests
