Z1-R Tank Drain Elbow
- wheelysteve
Bit of a long shot, but has anyone got one of these elbows (Part No. 52014-1001) ?
If not, has anyone found a suitable replacement to do the job ?
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Z1-R Tank Drain Elbow
this is similar but one side is about 6mm the other between 8mm & 10mm
https://www.ebay.ie/itm/Kawasaki-39062- ... 2032446630
Suprised if partssweden have it, they have never had anything when I have asked for
DavidZ1R wrote:Suprised if partssweden have it, they have never had anything when I have asked for
normally if it shows a shopping cart it means they have it in stock ?
I replaced mine about 5 years ago but could not find an original for sale.
The problem with the original is It is made in 2 halves (lengthwise) and over time it literally falls apart.
So I bought a couple of these off ebay & cut the one I have in use down to size
It is basically a right angle fuel line with reinforcing cords running down the length.
I put an old magazine I had lying around, in the picture - to give an idea of size / scale.
I can't remember the supplier name now but a bit of searching should bring up similar items.
if you are not worried about 100% originality, something like this is a practical alternative.
010
z1bman wrote:DavidZ1R wrote:Suprised if partssweden have it, they have never had anything when I have asked for
Err not in their case, tried several times, never have the items.
this overflow hose is available from cradley £14
- Attachments
- 92190-1307.jpg (5.27 KiB) Viewed 4593 times
- wheelysteve
Thanks for the replies.
I ordered 1 of these on the off chance it might fit......which it does perfectly. It's a fuel pipe elbow for a Fiesta Mk3 diesel.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
wheelysteve wrote:Thanks for the replies.
nice but do you have the rest of it ?
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2026
- wheelysteve
I'll fit an 8mm push fit straight connector to the other end and then it's a length of fuel hose .
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- bulldogbobby
Got exactly the same problem with mine. Completely knackered! Just ordered the Fiesta one off ebay - was really struggling to find anything suitable so thanks for the info!
The mystery is solved!...
I recently bought a Z1R for restoration, and started looking at it last weekend. I took off the tank and saw the boss there and was scratching my head as to what it was for
Where does the overflow pipe run too exactly. There is what looks like a pipe boss on the plastic fuel sender cover, surely it doesn't connect to that??
The main fuel inlet to carbs is between #2 and #3, there are also inlets between #1 and #2 and #3 and #4, is it one of these, if not what are they for?
Sorry, I am an injection man, havent messed with Carbs for years and don't have a relevant manual. Is there a specific manual for Z1r?, or does anyone have one lurking around they want to part with??
Rob
Rob
paid up member
- warren3200gt
Allens do L fuel line parts http://www.allensperformance.co.uk/shop/ look under fuel line parts/fuel line accessories
PUM 488 June 2023
rpeters wrote:The mystery is solved!...
Rob
The inlets between 1 an 2 , and 3 and 4 are vent tubes for the carbs that run back and clip into the air box lid then just end down behind the side panel, tucked away, the sender cover joints into an overflow pipe that weaves it's way back tucking in to end up down behind the left panel, the other side with said elbow does similar but on the right hand side, many tanks had them removed years ago.
Users browsing this forum: FOZ1A and 109 guests
