KZ front hub dust cover WTD
ANZed
#1 PostAuthor: ANZed » Mon Feb 12, 2018 1:13 pm
Wanted
r/h front hub dust cover off a KZ1000 single disc set-up, must be a few around has anyone got one they would be willing to part with.
Re: KZ front hub dust cover WTD
#2 PostAuthor: z1bman » Mon Feb 12, 2018 4:56 pm
walshyco
#3 PostAuthor: walshyco » Mon Feb 12, 2018 5:06 pm
http://www.z-power.co.uk/dust-cover-front-wheel-right
Do you want the flat one or the domed one?
ANZed
#4 PostAuthor: ANZed » Mon Feb 12, 2018 5:40 pm
Thanks for the replies guys but I had one delivered from Z Power last week same as the two above but they are for fitting with a twin disc set-up, the right side one (as you sit on the bike) on the single disc set-up is a deeper cone shape to accommodate the additional distance to the hub that the second disc would fill on a uk bike. anyone who has converted a KZ single disc bike to twin disc should have the part I am after spare.
#5 PostAuthor: ADRIAN H » Tue Feb 13, 2018 8:43 am
Think I may have one. Will have a look later on.
#6 PostAuthor: PAULJAC47 » Tue Feb 13, 2018 9:05 am
If you havent got one Adrian i have one,if its the rh one dished with two small mounting holes,pm me if interested.Paul j
ANZed
#7 PostAuthor: ANZed » Tue Feb 13, 2018 10:42 am
Adrian / Paul
PMed you both thanks
#8 PostAuthor: ADRIAN H » Tue Feb 13, 2018 4:09 pm
This is what I have not Solid but not perfect, slight dent to side and where spindle goes through some distortion - this is on a 4 hole disc hub.
If the one Paul has is in better condition I'd go with his.
ANZed
#9 PostAuthor: ANZed » Fri Feb 16, 2018 8:23 pm
Thanks Paul it arrived yesterday very pleased.
