Hi I’m looking for good rust free z1000H tank .as one I’ve got as lot of rust inside and out or any good tips best way Try and remove it.
Regards
Z1000h Tank
Re: Z1000h Tank
They are very rare so good luck. I ended up getting one repaired as it had pin holes in it.
- 8 Valve Mark
Re: Z1000h Tank
try oxalic acid for the inside rust, its in crystal form n water soluble n a cupful to a gallon of water, left for 24hrs should nuke the rust, leaving a black film that can be cleaned off with solvents or high pressure water. its available on ebay about £5 a kilo..i haven't tried it yet its a tip i only got recently from across the pond.. m
Re: Z1000h Tank
Thanks I will give it a go
Users browsing this forum: No registered users and 129 guests
