I have been/am chasing a low speed fault round a Z1000 and would like to eliminate the ignition system.
So..I would like to purchase, if anyone has one spare, a complete points set-up, ie backing plate, points, condensers, advance unit and points cam.
I know the advance unit is used on most electronic conversion set-ups, so may be the trickiest bit, so I would be interested in everything else including the cam, which I can fit on my advance unit.
Thank you.
Points
- ZedHead
Points
Mark.
Mark.
Re: Points
think I might have a complete point and backing plate set, but no advancer though.
Let me go have a look.
Re: Points
I have most of a Z1000 (early type) advancer.
It is missing; the cam (did have a Dyna 'S' on it) now long gone, and unfortunately it is also missing the two tiny damper pads from the bob weights.
Mechanically it's otherwise sound with good springs,... its marked 005.
Yours if you want it its no use to me.
Have you still got the tiny thin shim behind the cam on top of the base plate?
If so you could try taking it off, ive known them to crack and jam the cam!
Re: Points
I may have a couple of complete sets, including backplate, TEC points, condensers, and advancers.
Will take a look tomorrow afternoon (Friday).
PM me if you don't see a reply.
Will
Will
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
- ZedHead
Re: Points
Al wrote:I have most of a Z1000 (early type) advancer.
Thanks Al, but that's the bit I do have with the Dyna pick-up fitted.
Mark.
Mark.
- ZedHead
Re: Points
Big Fluff wrote:I may have a couple of complete sets, including backplate, TEC points, condensers, and advancers.
Will
Thanks Will.
Mark.
Mark.
Users browsing this forum: No registered users and 136 guests
