Need a MK2 inner sprocket cover if anyone has one hiding in th egarage.
Not sure if other Z1000 will fit also?
Rob
Z1000 MK2 Inner Sprocket cover
paid up member
Re: Z1000 MK2 Inner Sprocket cover
Hi Rob
I looked it up in the parts manual, they have the same parts number(14025-1106) so you might expect that a Z1000A1/A2 inner sprocket cover will fit on a Z1000A3 or A4 engine. Take a look for yourself at CMS.nl .
Good luck with the search.
Two wheel Spares (D&K) I've looked at converting my shaftie motor to chain & mines an E2
More Smiles Per Mile
try z power, they list them for 900-1000
Hi Guys, the later ones are definitely different, so early ones won't fit. I was reliably informed by knowledgeable club members when looking at converting an ST to chain drive and I have compared the inner sprocket cover from an early engine to the bevel box off the ST and some of the holes line up, but not all, I was advised to use earlier crankcases as the inner cover you are looking for are much rarer. I have had some very good parts from the USA via ebay, you just have to factor in shipping and duty, but often cheaper than Uk prices, cheers, Mick
Users browsing this forum: No registered users and 112 guests
