I’m looking for a rear near side indicator bracket, mine is bent and because it’s double skin I’m having trouble straightening it.I was hoping someone had a scrap frame they could cut one off.
Please pm me if you have
Nick.
1976 kz or z900 frame parts
- 8 Valve Mark
Re: 1976 kz or z990 frame parts
try looking for a kh,100/125, z200, 250,400 etc frame as the indicator mounts are so similar they're probably the same dimensions.or the easiest, cheapest option:get a good local metal worker/welder to remove, straighten and re-install your existing mounts.bosh! easy m ps scrap 900 frames no longer exist as far as i know. good luck though
Hi Guys, I have some frame parts currently on ebay from a front end damaged frame. I also have another rear frame section that I could sell if required, which has the rear brackets you want. Cheers, Mick
Hi mick, it’s actually the offside bracket I need I was looking at it with the frame upside down
How much would you want for your bracket?
Nick.
Nick.
Users browsing this forum: No registered users and 98 guests
