Gpz style twin headlight fairing
Would anyone have one of these for sale or tell me where i can get one please?
Re: Gpz style twin headlight fairing
Skidmarx used to do them. Bear in mind that the generator may have trouble running with both lights on for extended periods. I uprated the generator with a heavy duty one from electrex world but I don't think they do them anymore. I also use HID's in the double headlamp fairing to lower the amperage but when I found a genuine square fairing I sold the double.........
If you mean B2 style I think I've got one but it may take a day or two to check.
Gus
Gus
"Set the GRINDER on it"
Taff, do you mean that mine has an upgraded generator??
If the generator has grey insulation then yes, if it's brown then no. I'm not sure whether the upgraded generator is in your B1 or my 1170R engine
Thanks Gus.
It’s in your 1170R.
- Chunks
I have one you might be want to have a look at
