Hi, does anyone know of a pair of forks for sale to fit a 1976 Z900?
I want to refurb a set then just swop mine over.and keep mine as spares.
Dero
Z900 forks
- ZedHead
Re: Z900 forks
think z1000 a seris may be the same ?https://www.ebay.co.uk/itm/Kawasaki-kz1000-z1000-kz900-z900-forks/233225017097?hash=item364d4b5709:g:Ng4AAOSwrw1csxc3
Re: Z900 forks
According to Partzilla
This product fits the following:
Kawasaki Motorcycle 1976 KZ900-A4
Related Fitment
This Kawasaki 44001-175 FORK-FRONT Not Available fits the following models and components:
Kawasaki Motorcycle 1976 KZ900-A4 Front Fork
Kawasaki Motorcycle 1977 KZ900-A5 Front Fork
Kawasaki Motorcycle 1976 LTD - KZ900-B1 Front Fork
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2A FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3A FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1980 KZ1000 - KZ1000-A4 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1977 KZ1000 - KZ1000-A1 FRONT FORK (KZ1000-A1)
Gus
Related Fitment
Gus
"Set the GRINDER on it"
Re: Z900 forks
Thanks Gus
- ZedHead
Re: Z900 forks
Gus wrote:According to Partzilla
Related Fitment
Gus
Be careful, this is misleading as it is the way the parts fiches are labelled. only theZ900A4 or A5 and the Z1000A1 from 1977 has the same forks, the A2, A3 A4 from 1978 and 1979 are not the same as they have calipers behind the leg.
That is what the list above says, if you read it carefully, but it would be easy to think the A2 etc also do, but it's the way the fiches are accessed.
Mark.
Mark.
- warren3200gt
Re: Z900 forks
77 650b are the same also. Front caliper.
PUM 488 June 2023
Re: Z900 forks
I’ve got one for some reason - it’s a LH stamped K220L inside the leg, it’s missing the axle cup. I can put up pics if it might be any use. It’s probably off a Z1000A1. Been sitting for years but would refurb.
Re: Z900 forks
warren3200gt wrote:77 650b are the same also. Front caliper.
Z650 Fork legs are shorter
Zeds-R-Us
- warren3200gt
Re: Z900 forks
000zeds wrote:warren3200gt wrote:77 650b are the same also. Front caliper.
Good spot, by about an inch and half.
PUM 488 June 2023
Re: Z900 forks
Thanks for the help gents
Re: Z900 forks
Think i might have some if your still looking, would have to dig them out of the pile of H2 forks there with
Re: Z900 forks
I've got a pair in the garage pm me if you don't get sorted. They have the oil drain screw on the opposite side to the caliper mounts.
Users browsing this forum: No registered users and 139 guests
