As above wanted a Locating plate for J,R GPz rhs switch. If anyone has a broken or incomplete switch they don’t need all I need is the metal plate which screws inside that has the small locating spigot for the bars. The previous owner ground them off in his enthusiasm to fit Renthals meaning the switch turns unless it’s over tightened, I’m putting the standard bard back on having got them re-chromed, if anyone has one of these they don’t need it would save a bit of arsing about. At the same time if there’s a longer screw from that switch (5x40 black) in good shape I’d like one of those too...
I don’t know why people butcher switches instead of drilling a small hole in the new bars, my mate bought a ZRX they guy had done the same thing except the Rex pin is plastic they’d just broken them off...
Anyway here’s the bit I need, the metal plate held In by the two wee screws. It should have a protruding spud where the grind mark is... thanks in advance
Locating plate J,R GPz rhs switch
- paul doran
Re: Locating plate J,R GPz rhs switch
Paul I’ll give you a call tomorrow evening
I’ll have one as well if Paul struggles.
- paul doran
I've got a whole switch if you want it
Thanks for the help sorted
Users browsing this forum: No registered users and 121 guests
