Z900 A4 Air Box - wanted
- new poster
Just discovered my air box isn't original/correct, the one i have is marked KHI DGM 31311 S and KHI DGM 33280 S, could be off a Z1R but only based on some searches I've done. Will be happy to let this go if I can swap or source the correct 900 A4 air box....
- warren3200gt
Re: Z900 A4 Air Box - wanted
Pretty much made of unobtainium. On ebay for 5 or 6 hundred if you can find one and then make sure its complete.
PUM 488 June 2023
- Regular Poster
Give Ross Hensgen a shout. kawasakisupport@live.com.au
He is making the repo a4 airbox, he told me about 5 weeks ago that he's almost perfected the job.... the airbox silencers he makes are awesome and identical...
As has been said, pretty rare and go for £500 to £700 when they do.
From what I've heard the Aussie repros will sell for similar.
The airbox you have will work just fine, so no point in changing it unless you need it to be authentic.
- new poster
Thanks Peeps, i guessed as much from the searches i did and yep, tbh I didn;t even realise the one i had wasn't quite right until i took it off, so I'll stick with it until the magic fairies get me a genuine one for less than the cost of a holiday.
John, to make it look a little more authentic, just use a 900 silencer under the seat..
Users browsing this forum: No registered users and 112 guests
