Z1000 rear brake push rod
Hi all, I am trying to get hold of a rear brake push rod, and fixing bolt, the adjustable one that bolts to the brake pedal and operates the rear master cylinder. Thanks in advance. Sean.
Re: Z1000 rear brake push rod
Try John Browse M/C 01978 355556 as he is good for used spares
Zeds-R-Us
I had a stainless steel one made by Phil Denton engineering about 3 years ago.
