Deep braced swingarm
Looking for a deep braced swingarm davida/metmachex/jmc, something that needs work going to end up black, missing bits what's out there, to go in my Z1-R may monoshock if the right arm comes up at the right price
Re: Deep braced swingarm
I have a Metmachex that I bought for my Z650, but ended up fitting another one in the end so this one has been an ongoing project really. Its not a deep brace though - its shallow brace.
Its like the one pictured, if its any good I will dig it out and take photos of the actual item - it would need painting or polishing, but its had inserts added for paddock stand bobbins. The chain guard mounts had been cut off, but I had some new ones added - they can be cut down to fit whatever setup you end up with (like I said its been work in progress for ages lol)
It would have the thicker rear axle for the Z9/1000 etc and the correct spindle adjusters cos I used the smaller axle rig on my 650
The front end is the same on all the 650/1000 etc cos I have a 1000 swinger in my 650 at the mo
Any good - give me a shout
- warren3200gt
I might be interested if Pauls not Charlie.
PUM 488 June 2023
I have a Deep Braced Metmachex Swinging arm I have just removed from my 1976 Z900 if you have not found one.
Regards Derrick
Regards Derrick
Thanks peeps, messages sent to both, anybody else I'm after all options
Dero, do you know if that will fit a Z1000, coz it looks like there’s a mounting for the torque arm on there, maybe they are made to fit both? Sean.
I’m not sure it will fit the Z1000.
I took it off a 1976 Z900, it was running a 140/ 80/18 with room at each side.
Thanks peeps I've now bought a arm, forgot to update sorry
GIT! did you buy this off egay for just over a £120 squid?
I'm the muppet you you had against you LOL!
drew
drew
trikerdrew wrote:GIT! did you buy this off egay for just over a £120 squid?
drew
No mate bought a davida private, that will slot straight in, which one was you bidding on
Slightly off-topic, I know but, does that under bracing on the JMC / Metmachex actually do anything?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
drew
Funny thing similar happend once, my mate seen a yoshimura carbon end can on ebay with very light damage on the back, bearing in mind this is one of my best mates who I see probably 5 times a week, so he said I'm skint cant afford it, so with that in mind I bid on it and won it for just over 20 quid, I seen him that evening he said I got outbid on that end can, I said you know I won that end can, he bid me up i would of won it for 99p, oh well it's on his sons bike now and I'm 20odd quid down
Users browsing this forum: No registered users and 174 guests
