Piston ring compression tool
harri183
#1 PostAuthor: harri183 » Wed Feb 09, 2022 1:32 pm
Anyone got the Kawasaki piston ring compression tool for sale or rent. Happy to pay postage and a rental fee. It’s for the Z1100. Cheers
Re: Piston ring compression tool
#2 PostAuthor: warren3200gt » Wed Feb 09, 2022 3:02 pm
You don't need it. Cut hoops from a fizzy drinks bottle, slit it so the slit ends can overlap. Long cable tie it around the rings.
Simples. :up
#3 PostAuthor: ADRIAN H » Wed Feb 09, 2022 5:02 pm
I have one that I could be persuaded to part with, ( not sure if it’s correct for a Z1100) .
But to be honest, I found that it is easier to use strips of a plastic bottle with cable ties.
Good luck
harri183
#4 PostAuthor: harri183 » Wed Feb 09, 2022 7:52 pm
Cheers all will give it a go with the bottle and cable ties first then. Cheers
