Rickman rear sprocket help
Hi Guys,I am looking at replacing the rear sprocket on my CR and was hoping one of you kind gentlemen could tell me the distance between bolt holes on a standard Z900 sprocket ,the sprocket I have at the moment has bolt holes at 65mm apart, I am unsure if the Rickman rear hub(wire wheels)will take a standard kwaka sprocket ,the one I have appears to be machined out to fit the Rickman hub.Cheers Ken.
Steve Cooke
- ZedHead
