billet engine mounts
If i make some 10mm billet engine mounts where can i get some longer engine bolts?
Brian,
Phil Denton engineering could probably do you stainless ones made to teh length you want.
I know this is cheeky but,
If you are getting some 10mm engine plates made up, would you consider knocking up an additional set for me?
If you would let me know, as I was looking at the pmc ones and boy are they overpriced.
Phil
Phil
