GSXR 1100 USD Fork conversion
angeleddie
#1 PostAuthor: angeleddie » Tue Oct 27, 2009 9:26 pm
Hello Guys,
I have been offered a complete GSXR 1100 front end for reasonable money. Its the USD version. Thinking maybe I could fit it to either my a1 or J1. Can anyone offer any sensible advice based on experience?
Would the fork legs need extended?
Angeleddie
#2 PostAuthor: Pigford » Tue Oct 27, 2009 9:29 pm
I've got stepped yokes.... Not cheap though :shock:
Early Gixxer USD forks (early 90's) are longest of Suzooki forks...
Ginger Bear has recently done his bike.... :wink:
If you change your mind about the purchase, give me a shout for a bid :wink:
angeleddie
#3 PostAuthor: angeleddie » Tue Oct 27, 2009 9:38 pm
Saw you running at Santa Pod a cpl of weeks ago, bike looking & sounding good
How much is 'not cheap'? for the stepped yokes?
Angeleddie
#4 PostAuthor: Pigford » Tue Oct 27, 2009 9:54 pm
Hmmmm.... looking at £500 +
I think it'll be cheaper to get front end with yokes. Then press your Zed stem out & get it fitted to the Suzooki yokes.... Simples :wink:
Then get some extensions fitted in the top of the forks..... :twisted: (Like wot GB had done)
#5 PostAuthor: chrisu » Wed Oct 28, 2009 8:05 am
like this..........
#6 PostAuthor: Ginger Bear » Wed Oct 28, 2009 7:50 pm
Angeleddie, You'll find it's all a load of greif, so don't bother. Don't bother sending 'em in Piggy's direction either....... Send 'em MY WAY :cl
Only joking. I believe the early GSXR'S (oil cooled) have the longest Suzuki USD forks, I'm sure Piggy'll confirm this. Easiest/cheapest way as Piggy says is to use GSXR1100 yokes & change the stem. It may be possible to use the GSXR stem, but alter the bearings, these may help http://simplybearings.co.uk/shop/
You will find the forks are too short..... You may think, like I did that the nose down drag racer look would be cool. You will find it is far from practical. The side stand will be too long for one, then you'll have the worry of the mudguard hitting the exhaust :shock:
Don't be put off, I had some 50mm extensions made (£100 the pair) & managed to internally extend by another 40mm. I would think with GSXR1100 forks you could probably do it internally by about 40mm & that might be enough..
Have a look at my Z1000 Money Muncher thread. Feel free to PM me if you want & I'll go into more detail.
#7 PostAuthor: chrisNI » Wed Oct 28, 2009 8:09 pm
I think I have a set of unused fork extensions almost identical to GB's surplus to requirements - take £90 to recoup some costs from an aborted front end (due to disappearance of some parts and a supplier am going ZX9 RWU on that one now) if anyone's interested can post pics. The beauty about these ones is they exist and you can have them right away rather than phoning some machinist for months (or even years....)
Users browsing this forum: No registered users and 106 guests
