Harris 4-1
PETER KZ1A
Harris 4-1
#1 PostAuthor: PETER KZ1A » Wed Dec 16, 2009 5:50 am
Hi from windy Western Australia,
Anyone know the set up with collets on Harris 4-1 pipe. Early 80's style.The pipe is stamped Z1000,mines a Z1a.....collets from 900 too small.Does it require Z1000 collets or Harris ones?
Thanks Pete
#2 PostAuthor: kev edwards » Wed Dec 16, 2009 9:30 am
Harris system does not have collets,they have their own clamps,are you sure you have the right headers,a photo may help with identifying what you have. :)
steve.w
#3 PostAuthor: steve.w » Wed Dec 16, 2009 7:08 pm
early harris pipes require collets they are made to suit ure standard collets and clamps so ull need collets n clamps for a z1000
jimmock
Z1000/900 HEADERS
#4 PostAuthor: jimmock » Sat Dec 19, 2009 10:28 pm
I have a Harris on my 900A4. It is stamped Z1000. The only difference I could see was the size of the holes on the clamps ie 8mm instead of 6mm. I just used a repair washer before I put the 6mm nuts on.
Jimmock
Jimmock. :wnkr
I hate people I don't like !
#5 PostAuthor: chrisNI » Mon Dec 21, 2009 11:31 am
steve.w wrote:early harris pipes require collets they are made to suit ure standard collets and clamps so ull need collets n clamps for a z1000
What's early? I have a Z1000 Harris from about '83 or '84 and it has the non collet set-up same as the rest.
BShaw
#6 PostAuthor: BShaw » Mon Dec 21, 2009 3:51 pm
I am sure that i used collets with a harris on 900 & 1000 heads In fact i did coz I lost a pair once and went to martin smiths house en route to wherever and pinched a pair.
Baza
Steve Cooke
#7 PostAuthor: Steve Cooke » Mon Dec 21, 2009 6:28 pm
My last Z1000 had a harris and I have two in the garage now and none of them use split collets, they all have a double skin at the entry to the head. Of the two I have now one has the double skin fixed and on the other the double skin will rotate and pushes up against a slightly flared end, the earlier of the two has the fixed skin.
