Mig/Arc welding what to disconnect ?
Hi all ,z1000j1 fitted with Boyer,need to do small weld arc/mig repair, is it just the case of battery disconnect ?or do you need to disconnect or isolate anything else to be safe?...Paul J..
Awwww
Perfect opportunity to tell him he needs to disconnect and remove all wiring loom, engine and any plastic or rubber components and you all bloody spoil it, humph
Yep just the battery, technically just the - terminal but i'd disconnect and remove in case you have heat seeking terminal cables like mine
You know you're getting old when you stop laughing at nasal hair trimmer adverts and start thinking, hmmmm.... you know, that looks useful!
to be honest, I would remove any electronic components - this would be the voltage rectifire and regulator if not combined unit. also electroinc ignotion if you have fitted.
for the few extra minutes it takes, it will save you a lot of maoney not having to replace either.
I am pretty sure I fried an alternator on a Land Rover so now as precaustion always remove electronic parts.
Users browsing this forum: Google [Bot] and 60 guests
