suspect boyer ignition
stephen lavery
- Regular Poster
i believe the boyer ign is playing up it keeps fouling the plugs (very black sooty) to be honest i have never been happy with it. the carbs are set and synchronised. my question is if i fit dyna s will the boyer micro coils suit the dyna? if not will have to go back to points and standard coils as a cheaper option. made reduntant so money is very tight.
stevie the babarian
Dyna S will definitely work with standard coils. Not sure about those micro-coils, but if they are in the reach of 3 to 5 Ohms primary resistance, they're good to go.
Otherwise you will have to get coils with 3 Ohms resistance, e.g. Suzuki Bandit ones will fit nicely and aren't to pricy at the breakers.
Greg
Greg
stephen lavery
- Regular Poster
stephen lavery wrote:thanks nanno, cant find any info on the resistance for the boyer micro coils. but i think i can lay my hands on a set of bandit coils.
If you have a multimeter, just measure the resistance between the two connectors, that go to the wiring harness. When it is above 2.5 Ohm and below (roughly) 5 ish. Then it'll work.
Greg
Users browsing this forum: No registered users and 88 guests
