Hi Guys.
I Drained the oil and replaced the Oil filter yersterday.
When I filled the engine with oil, it only took around 1.5 Ltrs before it registered full on the display window.
The filler cap has 3700CC (3.7 Ltrs) stamped on it.
Any one else encounter this, or know if I have enough oil in it?
Rob
Oil Capacity on KZ1000
- Mark Tiller
did you drain it via the sump plug(Big bolt)or just the oil filter drain screw and change filter?
how much came out?
did u drain it warm?
its deffinitely 3.7l though
how much came out?
07962421462
Might sound obvious but I would take the clutch cover off and clean the indicator window 1 and a half ltrs aint nowhere near enough
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- Chunks
paulmceleney wrote:Also worth taking the sump off and remove the oil pump and give it a clean its a easy job and well worth doing you will be surprised how much crap is stuck to the oil pump
Might do that if it,s not too much hassle. Do I need to remove the header pipes? Will I need a new sump gasket?
Drained the oil from the larger of the two bolts, and got the full 3.7 lts out. Happy Days.
- Mark Tiller
Users browsing this forum: drydockdavies and 120 guests
