Tyre width/swingarm question
Holeshot
#1 PostAuthor: Holeshot » Mon Aug 01, 2011 7:31 pm
How wide can I go on a 17" rear tyre when put into a JMC deep brace swingarm on a Z1000A2 before a) It will rub on the swing arm and b) it needs offset sprockets or spacers?
I'll be using a spoked wheel so can build in a small amount of offset to avoid the tyre rubbing the chain.
I'm thinking of using a 4.25 rim with a 160/80 tyre but if anyone's got any other suggestions..........
Thanks guys :)
#2 PostAuthor: Rich » Tue Aug 02, 2011 5:03 pm
a) don't know
b) 160 will need an offset front sprocket, how much depends on rear sprocket carrier, a 5/8 offset will clear the tyre but check the shocks for clearance.
Jumbo
#3 PostAuthor: Jumbo » Tue Aug 02, 2011 8:10 pm
This question I asked before the "meltdown" however I cannot really remember the full answer.
However I was going to ask GUYZED at the SW Rally as on his z1000 he I think had a 160 tyre on the back. Also on his listing for his z650 rebuild he appears to have a larger rim all ready for that build.
Unfortunately I got talking to COLDSUMMER at the SW about the pros and cons of ultrasonic cleaners and was so pissed I could not talk to GUYZED.
I do not think that Jägermeister is the correct cleaning fluid to put in a ultrasonic cleaner :D
LE to JOG on a z900
P.U.M.
Jumbo
#4 PostAuthor: Jumbo » Tue Aug 02, 2011 8:14 pm
This is the link to GUYZED's listing on his z650
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=14339
LE to JOG on a z900
P.U.M.
