clutch cable
- steve bowdler
clutch cable
Hi can someone tell me the lengths of a standard Uk clutch cable to that of an American imported bike.mine is the 1977 z1000ltd imported model but unsure if the bars have been changed.Thanks
The one I just removed from my US 78 Z1000 was a 1460mm, (inner cable length), this would have been US high bar spec, I have replaced that with a Barnett cable from Debbens, (1200mm?), which is still too long with my Renthal bars, I may have to go with a Z650 UK spec cable which is much shorter, around 1160mm or get the Barnett cut down a bit.
