larger wheels on Z1000 A1
evans
#1 PostAuthor: evans » Fri Nov 25, 2011 1:32 pm
Hi all
Want to replace the GPZ 900 rear wheel on my Z1000 A1 with something larger. I have a mechamex swinging arm on theree, so any ideas as to what might fit (with a spacer or two etc) would be much appreciated.
Chris
#2 PostAuthor: chrisNI » Fri Nov 25, 2011 11:52 pm
What width have you inside adjuster to inside adjuster?
#3 PostAuthor: Pigford » Sat Nov 26, 2011 8:43 am
I don't think they do much BIGGER wheels than 19" :shock:
Sorry, just had to reply with that "daft" comment.
A good way to go is Bandit 600 gear - front end needs a stem swap but that stuff is real cheap, and the 160 rear wheel is nice and fairly hassle free to fit :wink:
evans
#4 PostAuthor: evans » Sat Nov 26, 2011 11:55 am
There is about 7inches between the swinging arm to the brake caliper bracket.
Bandit 600 may seem the way to go though.
#5 PostAuthor: chrisNI » Sat Nov 26, 2011 8:04 pm
I just measured up the 4.5 Suzuki wheel (160 tyre) which came out of my 1000R - as has been said on here before the Suzuki three spokers are about the narrowest across the hub. This measures about 8 and a half inches from outside sprocket spacer to outside disc face the caliper hanger takes up about another inch. Going by that you'll be going well to get a narrower four and a half to fit that arm, short of going to spoke wheels with a Z1000 A1/A2 hub and lacing on what you like. Good job too but not a cheap option....
#6 PostAuthor: ADRIAN H » Sun Nov 27, 2011 10:37 am
Pigford wrote:I don't think they do much BIGGER wheels than 19" :shock:
:wink:
I have some 21 inch rims on a NSU Quickly. :lol: :lol:
