hi , dont ask why but i would like to fit the earlier side panels on to my a4 the right hand one does not seem to be a problem but the left hand side looks a bit off , any advice welcome .
The bike came fitted with the earlier air box when i bought it so no problem with that .
thanks
can i fit a earlier panel
Pretty sure 2 of the lugs line up but if I recall, the lower one needs repositioning.
Some of the later bikes had removable Brkts with a mounting point on.
If you can locate something like this, you might be able to fit that without taking to the hacksaw.
Of course, this is all dragged out of memory from 30 years ago...so could be all rubbish.
Dirk, I have looked at modifying the A4 to take Z1 series side covers and it is not easy. The biggest problem is, as you mention, the left hand side. and its to do with the seat key-lock position. I think if you can devise a way of not having this facility, it is possible and can look good.
