Rear Brake options?
MCZ900
Rear Brake options?
#1 PostAuthor: MCZ900 » Sat Feb 11, 2012 3:11 pm
Hi all can anyone help with my rear brake options , iv fitted a bandit rear end to my proj and you have to do away with the rear sub frame bit that the brake lever hangs off, not done any chopping yet untill i find a brake solution. is there anything out there? or can anyone point me in the right direction.
Cheers Ian.
1973 Z1 and 1976 Z900
#2 PostAuthor: Ginger Bear » Sat Feb 11, 2012 3:42 pm
Ian, Does the brake lever pivot/mount foul the swinger?
# 104
MCZ900
#3 PostAuthor: MCZ900 » Sat Feb 11, 2012 4:02 pm
Hi yes mate, i did here somewhere Lockheed do the full kit in japan?? including the external master cyl etc, wish i lived in Japan. any help, i have some cash i can throw at a solution.
Thanks Ian
#4 PostAuthor: Ginger Bear » Sat Feb 11, 2012 4:29 pm
Ian,
When I fitted a similar arm (GSXR600 SRAD) to my Z1000, I had to lose the brake pivot, I then fitted some rearset's mounted on the original footrest mounts, with the aid of an adaptor plate. fairly simple to do + you can make just about any rearset's fit.
# 104
MCZ900
#5 PostAuthor: MCZ900 » Sat Feb 11, 2012 4:34 pm
nice work ,what are those rearsets off? i like the look and the master cyl which bike did that come off?
Sorry so many questions lol
Users browsing this forum: Google [Bot] and 39 guests
