Sealing the stator wires
MotoV4
#1 PostAuthor: MotoV4 » Mon Apr 09, 2012 4:22 pm
Looking for advice on this. I have had to take the stator cover off for other reasons but there was a slight leak at the point the wires exit anyhow so trying to deal with that at the same time. I've got as far as cleaning the old gasket sealer off and was going to clean the oil off it and reseal it but as I didnt do a good job in the first place I was wondering if someone has done a few of these and knows the best way to ensure a good seal at the grommet where the 3 yellows go through.
#2 PostAuthor: Pigford » Mon Apr 09, 2012 4:46 pm
I always have hassle with this job - :evil: - so can't help :??
hillbilly
#3 PostAuthor: hillbilly » Mon Apr 09, 2012 4:56 pm
get the wires as clean as possible,then apply silicon ,leave off the motor to dry then put back together,with a bit of gasket goo to seal around casing.
#4 PostAuthor: Ginger Bear » Mon Apr 09, 2012 4:59 pm
# 104
MotoV4
#5 PostAuthor: MotoV4 » Tue Apr 10, 2012 1:04 am
Thanks alot fellas - I'll be giving that a go, checked that link and that makes sense, will take a bit more time with it this time around.
Users browsing this forum: bedlow1 and 60 guests
