shock info
sme
shock info
#1 PostAuthor: sme » Wed Apr 25, 2012 8:38 am
this is fitted to a gpz1100,
i need to id it,
and need to replace the top eye spacer/bearing,
it needs pushed out as its held in with circlips
where can i get a replacement?
tricky
#2 PostAuthor: tricky » Wed Apr 25, 2012 8:40 pm
hi sme, i could be wrong but it could be an, e=mc brand shock, if you can press the bearing out, go to your local bearing supplier and ask if they can match it up, hope this helps tricky.
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Thu Apr 26, 2012 8:46 am
Second Tricky's comment it looks like an emc, but regardless knock the bearing out and get a replacement and seals. try
www.simplybearings.co.uk
great service and good online site to help you identify what you need.
nealblath
#4 PostAuthor: nealblath » Thu Apr 26, 2012 9:15 am
KWACKERZ1 wrote:Second Tricky's comment it looks like an emc, but regardless knock the bearing out and get a replacement and seals. try
agree with Kwacker.........I've replaced loads of the shock bearings and simply bearings have most of them at afraction of original parts prices!
