Z1R wiring loom
coldsummer
Z1R wiring loom
#1 PostAuthor: coldsummer » Sat Jun 02, 2012 10:59 am
Friend of mine has a Z1r which he has owned since nearly new and he is having constant problems with the wiring. Does anyone know if a replica is available (like the Z1 ones)?
compo z1r
Re: Z1R wiring loom
#2 PostAuthor: compo z1r » Sat Jun 02, 2012 9:08 pm
coldsummer wrote:Friend of mine has a Z1r which he has owned since nearly new and he is having constant problems with the wiring. Does anyone know if a replica is available (like the Z1 ones)?
no not as yet simon i know some have had some made up from scratch
and depends on whats wrong ive got a spare he can have to make good if wanted and some of the connector blocks are available :wink:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
000zeds
#3 PostAuthor: 000zeds » Sat Jun 02, 2012 9:34 pm
Z-Power have looms to suit Z1000 are the Z1R ones much different :?:
Zeds-R-Us
compo z1r
#4 PostAuthor: compo z1r » Sat Jun 02, 2012 9:36 pm
twozeds wrote:Z-Power have looms to suit Z1000 are the Z1R ones much different :?:
yes a1-a2 do not fit
coldsummer
#5 PostAuthor: coldsummer » Sat Jun 02, 2012 9:46 pm
Thank compo, I thought that was the case as I couldn't see any on the Z-power site (although that doesn't always mean anything). I think it has been repaired many times over the years and the connectors are all a bit brittle. He's coming down to Bristol soon so hopefully I'll catch up with him and find out a bit more about the issues. Thanks for the kind offer of your spare loom, I'll let you know if he needs it. Cheers.
#6 PostAuthor: z1bman » Sat Jun 02, 2012 9:50 pm
coldsummer
#7 PostAuthor: coldsummer » Sat Jun 02, 2012 9:55 pm
z1bman wrote:dont know if this is of any use ?
http://www.z-fever.de/ShopNeu/shop/show ... ts_id=1000
That's interesting, not sure if MKII is same as Z1R though? Pretty sure it could be adapted by someone with a bit of wiring know-how.
compo z1r
#8 PostAuthor: compo z1r » Sat Jun 02, 2012 10:08 pm
due to the z1r fairing it will need to be adapted to the clock loom which is z1r only :wink: for starters
compo z1r
#9 PostAuthor: compo z1r » Sat Jun 02, 2012 10:14 pm
just had a good look a lot different to z1r :roll:
HowieD
#10 PostAuthor: HowieD » Sun Jun 03, 2012 5:53 pm
Hi,
I used to have quite regular wiring things happening with my Z1-R. I made a complete new one (several times) with all the wire & connectors from here:
http://www.vehicle-wiring-products.eu
All you need is the original one as a pattern and the colour diagram from the manual. I found it better to build the loom actually on the bike too.
The latest reincarnation of mine uses waterproof mini connectors.
Hope that is some help
H
coldsummer
#11 PostAuthor: coldsummer » Sun Jun 03, 2012 7:07 pm
HowieD wrote:Hi,
H
Thanks Howie, that is an option although not as easy as buying a repro :wink:
gray
#12 PostAuthor: gray » Sun Jun 03, 2012 7:57 pm
Does Dave Ennis still recondition looms? he did mine a million years and 50,000 miles ago and it's still going strong, it was all horrible and scotchblocked and everything
gray
Users browsing this forum: Bing [Bot] and 38 guests
