Z1000 mk2
big green bus
Z1000 mk2
#1 PostAuthor: big green bus » Tue Jun 05, 2012 4:27 pm
Can you still get replacement needles for standard carbs? the ones on this are damaged . :roll:
000zeds
#2 PostAuthor: 000zeds » Tue Jun 05, 2012 10:15 pm
Z-Power should be able to help you , get the number off the needle as there are different ones :!:
Zeds-R-Us
#3 PostAuthor: ADRIAN H » Wed Jun 06, 2012 5:18 pm
You could try Allens performance, or motocarb . Have phoned up and used both in the past, found both helpful. Bought a set of Keihin carbs off Allens, and VM28 carb parts for another bike off motocarb.
http://www.allensperformance.co.uk/
http://www.motocarb.co.uk/
njwmct
Re: Z1000 mk2
#4 PostAuthor: njwmct » Wed Jun 06, 2012 8:01 pm
big green bus wrote:Can you still get replacement needles for standard carbs? the ones on this are damaged . :roll:
I would try NRP in Manchester as the helped me out with carb parts for Mark 2
http://www.nrp-carbs.co.uk/
The trick is to get the correct needles & needle jets as both items wear out
Also the needle & jet no.s differ depending whether it is a UK or US spec Mark2
Users browsing this forum: Bing [Bot] and 38 guests
