Z1000 A1 A2 rear hub disassembly
spondonges
#1 PostAuthor: spondonges » Sun Jul 08, 2012 9:20 am
Does anyone know how to take off the steel chrome plated spoke ring from the rear hub (spoked wire wheel) ??Is it an interference fit or is there a screw fixing hidden in it somewhere to release it??
Need to get it off to get rechromed :?: :?:
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
Mark Tiller
#2 PostAuthor: Mark Tiller » Sun Jul 08, 2012 9:47 am
I think it is interference/press fit
07962421462
#3 PostAuthor: ADRIAN H » Sun Jul 08, 2012 11:28 am
These are impossible to remove. I have tried heat, freezing - nothing will budge them. You could clean it up a and spray with a chrome finish.
mikey
#4 PostAuthor: mikey » Sun Jul 08, 2012 12:37 pm
I tried replating one of these last year
but could not succesfuly mask the alloy part of the hub.
#5 PostAuthor: z1bman » Sun Jul 08, 2012 1:12 pm
they can be removed but it is not a DIY job i had one removed years ago by a local engineering company who specialised in manufacturing old British bike crankshafts. they removed it with the use of a 50 ton press. they had to make a support to fit on the inside of the hub so the the chrome ring was supported then the hub was pressed through the chrome ring
spondonges
#6 PostAuthor: spondonges » Sun Jul 08, 2012 7:20 pm
z1bman wrote:they can be removed but it is not a DIY job i had one removed years ago by a local engineering company who specialised in manufacturing old British bike crankshafts. they removed it with the use of a 50 ton press. they had to make a support to fit on the inside of the hub so the the chrome ring was supported then the hub was pressed through the chrome ring
Definitely not a DIY job :shock: :shock: !!!!! Cheers z1bman, i'll ask a mate who works in an engineering shop, see if they can do it :)
Garn 1
#7 PostAuthor: Garn 1 » Sun Jul 08, 2012 8:13 pm
I thought as AdrianH did..... That the chrome piece could not be separated...
One of my many bad decisions! I was proved wrong! Z1Bman's 50 ton press is probably the answer!
RegardZ
DDZ900
a1/a2 rear spoke plate
#8 PostAuthor: DDZ900 » Sun Jul 08, 2012 8:22 pm
yeh iv recently tryed to remove one :oops: in the end up i powder coated it with chrome silver ! looked well smart :wink:
