exhaust gaskets
johnA
exhaust gaskets
#1 PostAuthor: johnA » Sun Feb 03, 2013 5:00 pm
hello gents could anyone help me by telling me how many exhaust gaskets you need to fit on a gpz1100 exhaust. just removed a harris 4 into 1 and there was two up each port is this corrrect or have they done this to get a better seal on a non standard system.many thanks in advance john
#2 PostAuthor: z1bman » Sun Feb 03, 2013 5:15 pm
you should only have one in each port but some after market exhausts do not have a thick enough flange on the end of the pipe where it fits into the head + when bolted up the exhaust clamp bottom's out against the cylinder head preventing it from compressing the gasket fully
Mark Tiller
#3 PostAuthor: Mark Tiller » Sun Feb 03, 2013 6:15 pm
Yup 1...although i had to use 2 second hand ones once to get an exhaust to seal ok
07962421462
