handlebar vibration
floydsz1
handlebar vibration
#1 PostAuthor: floydsz1 » Sun Aug 26, 2007 10:36 pm
im getting pins and needles in my right hand on me z1a, same thing happened on my a4, any ides how to stop it . Its not very bad just anoying, or do i have to just put up with it. I know bar ends help to cancel vibration, have thought about putting some lead in the end of the (standard) handlebars, just wondered if anyone has had same probs.
Steve S
#2 PostAuthor: Steve S » Mon Aug 27, 2007 9:35 am
I get it a little bit on my Z1A but only becomes annoying during a long ride,I just dont hold on so tight :lol:
rickman CRR
#3 PostAuthor: rickman CRR » Mon Aug 27, 2007 11:54 am
Assuming the carbs are balanced etc? This may sounds a bit flippant, but stop cruising at the same speed, keep off motorways if possible. The engine might only vibrate at a certain engine speed so give it some welly, use the gear box and scrub off the edges of your tyres.........yahoo lol
floydsz1
#4 PostAuthor: floydsz1 » Mon Aug 27, 2007 1:04 pm
everything is fine with the bike, and i dont ride it like a wus, only time i am cruising on it is when i am waiting for the race rep boys to catch up :lol: . blew a few off on way back from devils bridge yesterday, i like to set em up then ride round the outside off em on a corner, really winds them up. one day though im going to run out of ground clearence, :splat
#5 PostAuthor: Pigford » Mon Aug 27, 2007 2:15 pm
Those 'bar end weights' are designed to alter the resonation frequency, which changes the amplitude at which the harmonics build up & cause vibration. :?
Try adding weight in the handle bar ends (lead sheet or similar) and this should stop it :wink:
Davy Doherty
#6 PostAuthor: Davy Doherty » Mon Aug 27, 2007 4:04 pm
WHAT???
#7 PostAuthor: Pigford » Mon Aug 27, 2007 4:21 pm
Come on Davy, I even typed it nice & slowly for din-lows like you mate :roll:
Davy Doherty
#8 PostAuthor: Davy Doherty » Mon Aug 27, 2007 7:40 pm
Just kidden got it first time :?
floydsz1
#9 PostAuthor: floydsz1 » Mon Aug 27, 2007 10:13 pm
Cheers pigford,
i remember many years ago a mate raced a t500 suzuki :lol: in a special frame and that was bloody awful for vibration and i seem to remember we put lead in his clipons,.
its not that bad but anything that helps is worth a go as i tend to ride it as often as i can. I've broken both my wrist a couple of times in the past so they do get quite painful sometimes,Ill give it a go.
:fire
Steve R
#10 PostAuthor: Steve R » Wed Aug 29, 2007 7:14 pm
Try foam type handle bar grips , I had the same problem with pins and needles and putting those on has cured it completly.
Users browsing this forum: No registered users and 85 guests
