what's that sprocket all about Piggy ?............ he asked curiously
KeithZ1R wrote:Gavin I have two, you are welcome to one, just not how you would get it
KeithZ1R wrote:what's that sprocket all about Piggy ?............ he asked curiously
Gavin wrote:Just found this
http://www.coopersofstortford.co.uk/src ... tAodxBQApA
I will let you all know what it is like when it arrives.
Although when you press buy, it say that it could be upto 28days delivery
Garn 1 wrote:Gavin, I like your selection of the trolley and I'm sure it will let you move your engine around the garage or work-shop easily. However, you may have to leave your motor hanging around for some time.... If you have, I found it easier to store on a bench, hence, I remove the sump/oil-pan and the oil-pump so that the engine sits flat and easy to store.
I usually find a flat soft plate to sit the engine on, such as a cork place mat .. That seals out the dust and has a minimum foot print.
Regardz
