Some of you may had read my previous post about the bike smoking.
Well its still not sorted after 2 months.
Carbs all clean & working.Electrics all sorted & working .
Plug in No1 is black & sticky.When bike is left on side stand you get a big plume of smoke for a short while then ok.With a new plug in it fires & runs great for about 2 miles then start missing.
I changed the the valve seals & had guides checked with one in No1 being replaced.I was told other one was fine.
So im thinking the other one may not of been fine & should have been replaced.Or may be the heads is cracked & thats where the oils getting into the cylinder.
What would you do now
keep thoses wheels turning
				timyoungman
warm up the engine +remove the spark plugs + turn the engine over until the valves are on their maximum lift + see if there is any oil on the back of the valves. are the valves guides a solid fit in the head? i have known the exhaust valves to let oil between the guide + the head . has it got the large O rings at the bottom of the liners as these prevent oil getting between the the liner + the casting of the cylinder + leaking into the cylinder head. do you leave it on the side stand if so you might have a leaking carb?
						z1bman wrote:has it got the large O rings at the bottom of the liners as these prevent oil getting between the the liner + the casting of the cylinder + leaking into the cylinder head?
The O-rings are often left off as general opinion is they shouldn't be needed... but if they are its probably a bonus.
Cracked head... or dodgy liner/fit/barrel sounds highly possible.
Is it defo BLUE or WHITE smoke & not BLACK?
