Z1R Switchgear
#16 PostAuthor: z1bman » Sun Oct 13, 2013 5:30 pm
IF YOUR ORIGINAL SWITCH WIRING STILL HAS ITS ORIGINAL CONNECTORS SEND IT TO ME + I WILL SORT IT IF I CAN
Fred the Zed
#17 PostAuthor: Fred the Zed » Sun Oct 13, 2013 6:53 pm
z1bman wrote:IF YOUR ORIGINAL SWITCH WIRING STILL HAS ITS ORIGINAL CONNECTORS SEND IT TO ME + I WILL SORT IT IF I CAN
Wow. :shock: That's really decent of you but it would be a right lumber. Are you sure? I need to resolder a couple of the wires to the board for the hazard switch and then I was going to look at swapping all the internals over... is that what you had in mind? I'm fairly shite at electrics and I'm fearful that I'll end blowing fuses etc etc... if I get it wrong.
Fred
Paid Up Member
#18 PostAuthor: z1bman » Sun Oct 13, 2013 7:28 pm
FRED YOU HAVE A PM
