Also just noted that the petrol in the temp tank, which is open to the air, clouds up after a short while and 'blobs' of gel appear?
Racing engine
Racing engine
Now then, on my little z550 project, when the engine runs, and I give it a little rev, the engine speed takes a while to settle back down to idle speed, the balance of the carbs are spot on, thanks to Geoff's (Z1Parr) kind loan of his vacuum gauges, I have checked for leakage of air, all seems ok, I hope that the carb float levels are ok, spent all last weekend doing them
at a bit of a loss, any help
Hanging up is usually air past rubbers,spray wd40 around carb rubbers and see if improves temporarily,sometimes you think they are a good seal but if they are old and hard they normally leak specially if carbs have been off,,
oldzed wrote:no chance that the cam timing is out 1 tooth?
have seen that on a z1000 before
I hope not, the link count was perfect when I put it together, also the carb rubbers are new,
Have a look at this link
http://home.comcast.net/~loudgpz/GPZweb ... 00400.html
If Everything else is sealed then double check the valve timing. Should not take long and will rule it out.
regards
Craig
regards
Craig
member number 0664
Who can catch a Kawasaki?
A police helicopter
A police helicopter
Check also the mechanical advance unit, in particular the little weights that fly out.
The problem is that over the years the springs lose their tension due to the heat of the engine and the timing is then a bit too advanced at low revs.
This was exactly what happened on my Z500, but do bear in mind that you must fit the genuine springs to it and don't be tempted to fit springs that will simply fit and look right.!
Users browsing this forum: No registered users and 145 guests
