Hi Guys
I have just had my carbs refurbished but am a bit confused about what pipes I should fit to the two male plastic spigots that are just above the metal main fuel spigots. What are they for, and where do I route the pipes that I would connect to them? Any help as always greatly appreciated I havnt a pic of my carbs but you can clearly see the plastic spigots on this pic
http://www.z1enterprises.com/Images/Par ... C.1975.jpg
thanks in advance
GTB
Z1B Carbs - Plastic spigots
Lower ones are for fuel inlet and upper ones are for breather pipes which route out + up and go through either side of the plastic frame baffle plate and then hang down near top of airbox from what I recall.
from Mark
from Mark
Agree with Mark, except that these carbs are probably off a Z1 thru to Z1B, hence, those vent/ breather tubes simply feed up between the two tank rear support rubbers.
A better idea was to have them aiming towards the air-filter inlet as they did in the later Z900-A4 and Z1000 A1 & A2.
Users browsing this forum: No registered users and 97 guests
