Z1 ign switch 4 wire - is this copy a good replacement?
malmojoe
#1 PostAuthor: malmojoe » Sat Sep 06, 2014 9:19 pm
I was looking at replacement ignition switches for a Z1 but they all seem to have 6 wire connector blocks, the Z1 has a 4 wire connector block.
Then I found this one which has 4 wires, brown, white, blue and red - same as the Z1. Supposed to be for a 750 B1/B2 but I saw a similar one listed as for a Z650 C1.
I have found some wiring diagrams and the only ones with four wires are the Z750 B2 and the Z650 B1. The diagrams show the same connection grid as the European Z1, with the parking light. Has anyone used one of these or knows something I haven't been able to work out from the diagrams?
thanks
ebay item http://www.ebay.co.uk/itm/400427088012?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Z750 B2 wiring http://kz750twins.com/wp-content/uploads/2009/07/kz750b2.jpg
Z650 B1 wiring http://diagrams.kz650.info/wiring/images/KZ650-B1.jpg
:roll:
#2 PostAuthor: z1bman » Sun Sep 07, 2014 12:43 am
should do the job but you have this one specifically for the z1 but is a bit more expensive
http://www.z-fever.de/ShopNeu/shop/show ... 39g2qcogu4
malmojoe
#3 PostAuthor: malmojoe » Sun Sep 07, 2014 9:00 am
Thanks Z. I couldn't remember that web address. They've got some useful parts, especially for the euro bikes. Any idea where I can get a headlight fuse and holder?
#4 PostAuthor: z1bman » Sun Sep 07, 2014 10:38 am
if i where you i would use a more modern type of fuse holder something like this
http://www.ebay.co.uk/itm/WATERPROOF-30 ... 27b7d957ff
malmojoe
#5 PostAuthor: malmojoe » Sun Sep 07, 2014 11:19 am
sorry I wasn't think right this morning, I meant the resistor for the headlight. :??
#6 PostAuthor: z1bman » Sun Sep 07, 2014 11:33 am
you can bypass the resister by connecting the blue wires together & it improves the brightness a little
