Leaking tachometer drive
scott
Junior Section leader
#1 PostAuthor: scott » Sat Oct 04, 2014 11:34 am
I have a leak from my tachometer drive. I've replaced the unit with Zpower billet one, which comes with two orings and the oil seal....so why does it still weep?....looks like it's coming from the oil seal and not the orings due to the oil being on the cable and not running down the head. Could the shaft be worn to cause this?
#2 PostAuthor: chrisu » Sat Oct 04, 2014 11:55 am
i'd send the billet one back to zpower..........
just swapped the seals on mine and now spotless.
scott
#3 PostAuthor: scott » Sat Oct 11, 2014 2:16 pm
I replaced the shaft and now no more leak. I suspected the shaft because I've gone through too many oil seals
