Relay-Wired George.
#16 PostAuthor: z1bman » Sat Nov 29, 2014 7:50 pm
no mention of any diode?
wilsonsjw11
#17 PostAuthor: wilsonsjw11 » Sat Nov 29, 2014 7:55 pm
The diode would be within the relay housing.
Regards
Steve
z650freak
#18 PostAuthor: z650freak » Sat Nov 29, 2014 7:59 pm
wilsonsjw11 wrote:The diode would be within the relay housing.
Regards
Steve
Yes I understand that Steve but where's the diode protection in a standard system if you don't do the wired George mod....the point being why do you need one because of the mod as the surge is there anyway?....
z650freak
#19 PostAuthor: z650freak » Sat Nov 29, 2014 8:15 pm
Steve...have you read that one is needed with a diode somewhere or are you being cautious :?: (nothing wrong with that :D )
wilsonsjw11
#20 PostAuthor: wilsonsjw11 » Sat Nov 29, 2014 8:52 pm
z650freak wrote:Steve...have you read that one is needed with a diode somewhere or are you being cautious :?: (nothing wrong with that :D )
There has been a thread on this subject before and it was mentioned then about the diode, I believe the reason given was that the diode would prevent the field collapsing.
Regards
Steve
#21 PostAuthor: z1bman » Sat Nov 29, 2014 9:02 pm
Taffus
#22 PostAuthor: Taffus » Sat Nov 29, 2014 9:07 pm
electricity is generated by a wire passing through a magnetic field (or vice versa) When the coil on a relay is energised a magnetic field is created closing the relay.
when the relay is switched off from on, the field collapses and passes through the relay coil generating a voltage spike. Bear in mind this is the same principle as your ignition coil.
the diode provides a short circuit to earth for the energy generated to go straight to earth not into the main electrical system.
z650freak
#23 PostAuthor: z650freak » Sat Nov 29, 2014 9:15 pm
Taffus wrote:electricity is generated by a wire passing through a magnetic field (or vice versa) When the coil on a relay is energised a magnetic field is created closing the relay.
My reading of that then is that a diode isn't necessarily needed but is belt and braces....
z650freak
#24 PostAuthor: z650freak » Sat Nov 29, 2014 9:17 pm
Regards
Steve
Haven't seen that one Steve. Think it may just be someone's slant on the problem....
Taffus
#25 PostAuthor: Taffus » Sat Nov 29, 2014 9:18 pm
not really but it is good practice for sensitive electronics eg boyer stuff
z650freak
#26 PostAuthor: z650freak » Sat Nov 29, 2014 9:27 pm
Taffus wrote:not really but it is good practice for sensitive electronics eg boyer stuff
No great difference in price so may as well use one with a diode then....thanks for the link z1bman :lol:
Z1parR
#27 PostAuthor: Z1parR » Sat Nov 29, 2014 10:19 pm
KeithZ1R gave me the same advice as Taffus just has about fitting a diode protected relay .
They are both an electronics wizz so in the interests of ' good practice ' i fitted one .
0172 . Geoff Parr
z650freak
#28 PostAuthor: z650freak » Sat Nov 29, 2014 10:22 pm
Z1parR wrote:KeithZ1R gave me the same advice as Taffus just has about fitting a diode protected relay .
Where did you get your relay from?
Z1parR
#29 PostAuthor: Z1parR » Sat Nov 29, 2014 10:25 pm
I had one in a box in my garage , it's Ford one off a Transit :lol:
Vehicle Wiring Products sell them .
0172 . Geoff Parr
#30 PostAuthor: ZedHead » Sat Nov 29, 2014 10:29 pm
http://www.vehicle-wiring-products.eu/p ... with-diode
The diode is really only necessary if the relay coil is electronically switched but for what it costs it does no harm.
