Relay-Wired George.
wilsonsjw11
wilsonsjw11 wrote:The diode would be within the relay housing.
Regards
Steve
Yes I understand that Steve but where's the diode protection in a standard system if you don't do the wired George mod....the point being why do you need one because of the mod as the surge is there anyway?....
wilsonsjw11
z650freak wrote:Steve...have you read that one is needed with a diode somewhere or are you being cautious(nothing wrong with that
There has been a thread on this subject before and it was mentioned then about the diode, I believe the reason given was that the diode would prevent the field collapsing.
Regards
Steve
electricity is generated by a wire passing through a magnetic field (or vice versa) When the coil on a relay is energised a magnetic field is created closing the relay.
when the relay is switched off from on, the field collapses and passes through the relay coil generating a voltage spike. Bear in mind this is the same principle as your ignition coil.
the diode provides a short circuit to earth for the energy generated to go straight to earth not into the main electrical system.
Taffus wrote:electricity is generated by a wire passing through a magnetic field (or vice versa) When the coil on a relay is energised a magnetic field is created closing the relay.
My reading of that then is that a diode isn't necessarily needed but is belt and braces....
wilsonsjw11 wrote:z650freak wrote:Steve...have you read that one is needed with a diode somewhere or are you being cautious(nothing wrong with that
Regards
Steve
Haven't seen that one Steve. Think it may just be someone's slant on the problem....
http://www.vehicle-wiring-products.eu/p ... with-diode
The diode is really only necessary if the relay coil is electronically switched but for what it costs it does no harm.
