Hi All
I would be very greetful for info on jet sizes ( eg main jets, pilot jets, jet needle ,needle jets and air jet) for 29mm smoothbore carbs running standard airbox with 1015cc barrels on my 1975 Z1B. The sliders have a cut away of 2mm which is half a mill more than the standard Z1B sliders do you think this will be a problem and any info on float heights.
Thanks Glenn
29mm smoothbores on Z1B
smoothbores
Glenn
This should help-
main jet-120
air jet-.9
pilot jet-25
jet needle-5dl31-3 (middle)
needle jet-0.6
throttle valve-1.5
Any more info go to sudco.com
foz
This should help-
main jet-120
air jet-.9
pilot jet-25
needle jet-0.6
throttle valve-1.5
foz
Hi all
Thanks for the info, it was a great help.
I now need to no where i can obtain some Throttle valves 1.5 for the 29mm smoothbores as mine has 2.0 which suggests they came off a suzuki.
P S I sent an email to wiredgeorgetechstuff, are you supposed to send a donation at the same time or send it when you get a reply?
Hope some one can sort me out
Cheers Glenn
Cheers Glenn
Users browsing this forum: No registered users and 110 guests
