Z1000R fork/speedo drive
RUDDY
#1 PostAuthor: RUDDY » Fri Jan 30, 2015 4:21 pm
Guys, does anyone have, or could take, a photo of the lower fork and speedo drive on a Z1000R ?
I may have run into an issue on my build as the speedo drive gear does not appear to 'lock' securely into the fork leg to prevent it from spinning, very little contact between the gear and the protrusion on the fork.
The speedo did work on the bike prior to stripping it and I never took any detail photos of the lower fork area.
Cheers, Paul
85 Z1100R-1
martinz1000r
#2 PostAuthor: martinz1000r » Fri Jan 30, 2015 5:27 pm
is it the right one? The speedo drive on my Z900 looks similar to the ELR but is a lot thinner when side by side. I cant help on the photos as I non-standard wheels and electronic speedo on the Lawson but can measure thickness if that helps.
malmojoe
#3 PostAuthor: malmojoe » Fri Jan 30, 2015 5:42 pm
Here's mine Paul, right up against the inside of the fork. The protrusion on the drive goes behind the one on the fork.
RUDDY
#4 PostAuthor: RUDDY » Fri Jan 30, 2015 7:31 pm
Link isn't working for me Glyn
I have the spindle in but not the wheel, with the drive on the spindle pushed as far over towards the fork as possible the protrusion on the drive completely misses one stop on the fork and only just catches the other by a tiny amount.
Just took this, haven't cleaned or painted the drive part yet :wink:
The stop on the drive just touches the forward stop and I mean just touches.
And this is how much it misses the rear stop by, has the corner worn off the drive part ?
85 Z1100R-1
#5 PostAuthor: Al » Fri Jan 30, 2015 7:59 pm
Although it looks completely different the J1 speedo drive locates in exactly the same way. Same forks.
It looks like the corner is missing from the tab on the drive unit.
However, it is not necessary for it to be there it only sets the limits of where the cable outlet should be pointing.
When the wheel is complete and you tighten the two hex sleeve nuts up the outer body of the drive is 'locked' onto the spindle and only the internals are free to rotate.
Will be fine just as it is.
RUDDY
#6 PostAuthor: RUDDY » Fri Jan 30, 2015 8:19 pm
Cheers for the above, puts my mind to rest, I can get it cleaned and painted now.
Thanks guys ....its a learning curve :D
Paul
85 Z1100R-1
Z1parR
#7 PostAuthor: Z1parR » Fri Jan 30, 2015 8:22 pm
Every day's a school day Paul :D
That can only be a good thing .
0172 . Geoff Parr
DDZ900
speedo drive
#8 PostAuthor: DDZ900 » Sat Jan 31, 2015 9:34 am
Look in the genuine manual I gave ya ! :bye
RUDDY
Re: speedo drive
#9 PostAuthor: RUDDY » Sat Jan 31, 2015 9:53 am
DDZ900 wrote:Look in the genuine manual I gave ya ! :bye
Wouldn't it be easier just for you to come round and tell me, save me looking :D
Had the kettle ready for you yesterday.
85 Z1100R-1
Is Vic There
#10 PostAuthor: Is Vic There » Sat Jan 31, 2015 9:05 pm
Here you go Paul, hope this helps, can't believe how tatty my font end looks!
If you need anymore please let me know!
RUDDY
#11 PostAuthor: RUDDY » Sun Feb 01, 2015 10:04 am
Cheers mate
85 Z1100R-1
Is Vic There
#12 PostAuthor: Is Vic There » Sun Feb 01, 2015 10:21 am
Hope that's ok for you mate, let me know if you need anything else :D
