mikuni vm needle jets required
lescr
#31 PostAuthor: lescr » Thu Feb 05, 2015 9:25 pm
[quote="z1bman"]he has parts listed for vm 28mm on his parts list but the z1000a1 should have vm 26 as standard . are there any numbers stamped on the needle or the jet?[/quote]
nothing on the emulsion tube itself but has 256 0-4 on top needle jet. Stamping on needle itself is to small for me to read :lol:
The guys at NRP were ok just couldnt get through to allens that if there is no such carb as a vm28 why does kawasaki list them in their specs and manuals for the z1r, z1000mk2 and the st. He just kept telling me that mikuni only made 26mm, 29mm and 33mm vm carbs. I politely thanked him and put the phone down totally bewildered
snotie1965
#32 PostAuthor: snotie1965 » Thu Feb 05, 2015 9:35 pm
I think i have a set , i will check tomorrow and let you know....... they are off a standard Z1000 A1
#33 PostAuthor: z1bman » Thu Feb 05, 2015 10:27 pm
0-4 needle jet is not used on the z1000a but is from z1r d3 & z1000e1/e2 shaft usa models
lescr
#34 PostAuthor: lescr » Sat Feb 07, 2015 12:19 pm
[quote="z1bman"]0-4 needle jet is not used on the z1000a but is from z1r d3 & z1000e1/e2 shaft usa models[/quote]
Bang on with specs. The actual carbs came with a Z1R D3 I purchased a few years back. Sold off the rs34 flatsides that was on the bike when purchased and going back to standard set up. Should have said z1r in original post instead of z1000.
Guys at NRP said as long as the combined area of the holes are the same then it wont matter how many rows of holes they have. Opens up a few more options.
Users browsing this forum: No registered users and 82 guests
