gpz 750 r1 forks
Bullhead
gpz 750 r1 forks
#1 PostAuthor: Bullhead » Fri Feb 06, 2015 10:07 am
What psi are my forks supposed to be filled at. The table on the pdf manual has a part missing. Any help would be appreciated thanks
freddyz1r
#2 PostAuthor: freddyz1r » Fri Feb 06, 2015 10:30 am
I'd get this double checked :oops: but I think 10psi is the max. I was putting in my gt.
the seals can blow from about 15psi :?:
Blow them up with a pushbike pump or similar NOT COMPRESSOR, (they fill very quickly :oops:)
Cheerz freddy :D
freddyz1r
PUM 329
Bullhead
#3 PostAuthor: Bullhead » Fri Feb 06, 2015 10:49 am
freddyz1r wrote:I'd get this double checked :oops: but I think 10psi is the max. I was putting in my gt.
Cheerz freddy :D
Cheers for that Freddy. I can see that bit on the manual but it said another number on the pdf that was cut off. I will put 10 in and see what happens.I will use a bike pump too :D
