Guys,
I need some help here!!!
I have just about finished my Z1000 Ltd which is being rebuilt back as a Z1000 but i have a problem with the rear brake pedal spring.
the standard listed spring which wraps around the pedal just does not work at all--this is because the brake pedal mounting bracket and spindle is mounted on the footrest hanger A frame bottom tube where as the standard Z1000 bracket is mounted on the main frame diagonal tube--hence the point where the spring starts to produce tension is in a different place and does not work.
Anyone got a solution?????????
or any one got a part number for a Z1000 Ltd spring
all help much appreciated
Regards
Steve
Rear brake pedal spring--mystery
steve rees
- Regular Poster
Reecy m21
- london calling
steve rees
- Regular Poster
steve f
steve rees
- Regular Poster
Problem solved
Thanks for your help lads--problem now solved
It turns out that the KZ1000B2 has a Z900 frame and brake pedal mounting brackets but a pedal only used on the B1/B2 Ltd's different to the A1/A2 series.
flew across to J Browse in Wrexham and got a used one this morning now all will work.
Thanks again
Steve
Thanks again
Steve
Reecy m21
