Teething problems
Pinhead
Teething problems
#1 PostAuthor: Pinhead » Tue Mar 10, 2015 6:11 pm
Been out on the z900
Sounds like the chain is rubbing
And put the lights on I think it's a higher voltage
After about 5 mins the fuse poped do I put a lower voltage bulb in
#2 PostAuthor: PAULJAC47 » Tue Mar 10, 2015 6:16 pm
What fuse popped?lower voltage lamp wont help,what makes you think its the chain?
Pinhead
#3 PostAuthor: Pinhead » Tue Mar 10, 2015 6:27 pm
Just had a look at the fuse
Looks like I put the wrong fuse in should have been the 20amp
I put the 10amp in
The eyes are not as good these day
Building up to having lens replacement
The chain is a 530 I think it was rubbing on one side of the chain guard so I tied it over
Have to have a look under the cover
Pinhead
#4 PostAuthor: Pinhead » Wed Mar 11, 2015 7:55 pm
Just had the chain guard off and the clutch cover off
I can't see anything wrong
Chain looks like it's in line with the front sprocket
Refitted all the parts back on turning the wheel over by hand
It's not rubbing now i will take it out tomorrow to see if all is working
Could be that I fitted the chain guard wrong
floydsz1
#5 PostAuthor: floydsz1 » Wed Mar 11, 2015 8:20 pm
the front of the chaingaurd on the inside clips into 2 little brackets on the swingarm. Its very easy to not get it in properly and the gaurd then is to close to the chain
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
