KZ 650 Tap
Yellow
KZ 650 Tap
#1 PostAuthor: Yellow » Mon Mar 16, 2015 9:32 pm
Hi lads, I have this type tap on a 78 KZ650. Problem is it flows in all tap positions. What part do I replace to fix this?
#2 PostAuthor: z1bman » Mon Mar 16, 2015 9:55 pm
try replacing no 14 but i think there is an internal rubber seal with two holes which is not available as a separate part it is similar to the one that is fitted to the z1 fuel tap you will most likely end up replacing the complete tap
